GF 166 Rotary button and setting of squawk code
i would like to use the Rotary button of the GF 166 to Switch the squawk code of the PMDG 737 NGX.
Everthying is working fine except the fact that the numbers are changing too fast and that figures are beeing skipped because of this.
Its very tricky to catch the right numbers due to this ?
Any trick how to fix this ?
Thx !
Regards Andi
  • Hi Andi,
    In the settings tab, increase the values of the cmd and write delay sliders until you are happy.
  • I've set both values to max. Unfortunately i can hardly see any improvement. Any idea what my Problem is ?
  • The only other thing I can think of is that you have something set in GFConfig for the device.
  • I have fixed a number of issues with the GF166 which may help with this issue.
