777 EFIS after 3.7.0 update
Just updated the soft, and since, my left EFIS commands right DU and vice and versa.
I do not find the solution to re-invert.
Thank's
Yves
  • I found the same in my older NGX (not NGXu) but was able to change it back in GFIT by:
    Go to the EFIS tab, select Device 0
    Immediately below is a PMDG/iFly Only "Function" dropbox. Change Pilot to Copilot.
    I saved in the settings tab but had to shut down GFIT and open it (not just click Restart button)
    Does that work for you Yves?
    Good luck,
    Mike
  • Worked also for me.
    Thank's
    Yves
