Problem with the CDU driver i.c.w.the Git software.
Hello,
I've purchased the new PMDG B737NGXu but i've a problem with the CDU software.
I've updated GIT with the latest 64Bit driver (3.7.0.1) and the CDU with the latest 32Bit driver.
The software is running in W10 with P3DV4.5+HF2
But the CDU doesn't start with the new PMDG 737NGXu. In the log file is an Illegal_Operation error. See picture.
When i use my old PMDG 737-800 everything works fine. No problems at all.
I've attached pictures of the log files.
Do you have any solution or suggestion?
Ad
  • edited December 2019
    Log File of the PMDG 737NGXu
    Log file of the old PMDG 737NGX
  • Can you check the version of the software as I think it may still be the old one.
    I couldn't test another version, because at the startup i have to enter the User Key but i get: Registration Failed - 202 Exceeded Install counts.
    And which version for the CDU do i need?
    Thanks in advance.
    Ad
  • I have reset your install count. You need 2.0.3.0 64Bit version for P3D
  • Thanks, i'll check it this evening.
    Ad
    I did a check but unfortunately the driver of GIT 64BIT v.3701 doesn't work together with the CDU driver version 2030.
    Firts test:
    When i start at first the GIT software it's working well.
    Starting the CDU software after that than the CDU sofware freezes.
    Second test:
    Starting the CDU software first than it's running perfect.
    But when i start the GIT software i get the error as you can see at the attached picture.
    For info: My P3DV4 is running with the latest FSUIPC version 5.153
    Best wishes,
    Ad
  • edited January 2020
    Use the 64bit version of the Engravity Interface software and the 32bit version of GIT and the error should go away.
  • Hello Steve,
    That was the solution, both are running now. Many thanks for your help.
    But i've still a small problem with the CDU.
    The light of the EXEC button on the CDU doesn't work when needed.
    The function of the EXEC button is ok, but the button isn't hightlighted to activate a situation.
    I hope you have a solution for it.
    Best wishes,
    Ad
  • I'll look into it.
  • Thanks in advance. :)
    Ad
  • admin_pps said:
    I'll look into it.
    Some news about my EXEC button problem?
    Ad
  • This is fixed now. Download in the normal way.
  • I'm happy you didn't forget this small problem.
    After the update the EXEC button highlights again when it's needed for activation.
    Many thanks, Steve!
    Best wishes,
    Ad
  • edited August 2023
    Hello Steve,
    I have the same problem as before with P3Dv4.5 but now while using MSFS2020
    Second test:
    Starting the CDU software at first than it's running perfect.
    But when i start the GIT software i get an Goflight error as you can see at the attached picture.
    Both programs are running with the latest driver for MSFS2020
    I hope that you have a solution again.
    Best wishes,
    Ad
