Right display of GF 166 module not showing the ELEVATOR_TRIM_PCT of the PMDG 737
Hello,
is there any Chance to get the Elevator trim percentage of the PMDG 737 shown on the GF 166 Display ?
Thx !
Regards Andi
Hi Andi,
Having just debugged the code, none of the trim pct's work with any aircraft. The datatype and return value were set incorrectly. I'll update the code and issue a new version over the weekend.
New version is out now.
The values are correct as far as FSX see's them, but I guess since PMDG build a lot of custom stuff, its manipulated internally to be a different value. I would suggest you see if you can subtract or multiply a value via Light Action/Value to get them to sync up.
Here are the values..i hope you can help me what to set as light Action and light value
GF166 Display / PMDG 737
0,01/-30,55
0,51/-26,55
1,02/-22,55
4,51/4,55
5,99/15,94
6,51/19,94
As you can see...while the GF166 values go up with +0,5 the PMDG values increase by +4.
Any idea how to fix this Problem ?
Thx !
That idea is not going to work as there is no linear ratio to multiply the value against or a consistent value to add or subtract. e.g.
19.94 / 6.51 = 3.06.....
15.94 / 5.99 = 2.66......
19.94 - 6.51 = 13.43
15.94 - 5.99 = 9.95
There is no single value that can be added/subtracted or multiplied to get to the correct value.
The only thing I can do is build in specific support into the code to do the conversion and provide CLUSTER data to output the result.
If that is not too much work for you i would be very thankful if you can do that for me
Donation is guarenteed then
Regards Andi
