Prepar3d v2.4 crashes with goflight Interface tool mentioned in dll.xml
Dear All,
My Prepar3d v2.4 crashes (CTD) when I add the following lines into dll.xml:
<Launch.Addon>
<Disabled>False</Disabled>
<Path>D:\Lockheed Martin\GoFlight\GoFlight Interface Module.dll</Path>
</Launch.Addon>
The path is correct and is not in the main root of Prepar3d v2
I have a lot of products (dll's) from ORBX loaded into the dll.xml and they all load fine.
Just when I add the above described lines I will get a CTD during start up
Any guesses?
Greetings Martin
Hi Martin,
Have you tried changing the order its loaded in by repositioning it in dll.xml?
Can you copy your dll.xml file to a backup and then remove all dll's except Goflight Interface Module and see if it loads.
Hi Martin,
No, my development system is Win 8.1/64bit and it runs fine.
Can you try
1) Disabling any FSX utilities/addons/exe's that are running to see if they are causing the problem.
2) Remove GIT and goflight drivers and try installing GIT and the goflight drivers into c:\program files (x86)\goflight and try it again just in case there is a bug related to directory paths
