W10 error - Device USB\... was not migrated due to partial or ambiguous match
Hi All,
After a windows 10 update i saw that a device of goflight is not working anymore and w10 device manager stated in events:
"Device USB\(device path) was not migrated due to partial or ambiguous match.
Anybody with the same behaviour in windows 10?
Andrew
Andrew
This may help: https://www.minitool.com/news/device-not-migrated.html
Did try some of the suggestions. The problem is that a Goflight device uses the default usb driver in windows. Therefore i can't switch the driver to compatibility mode. Again it is a nightmare with goflight modules and windows for many years. Nothing by the way you can do anything about it.
Do you use other drivers in your environment or also the standard windows ones?
Thanks!
