VS - Xplane/Zibo
Looking for some advice.
I’m using the MCP PRO with Xplane and Zibo.
Everything is configured nicely and it works well.
The only problem I have is the VS rotary wheel.
I have it set as I believe it should be, but regardless of which way I turn the wheel it goes up both ways. Or if I change it round, it goes down both ways. Can’t for the life of get it to go Up with Up and Down with Down.
Is this a common fault or am I using the wrong commands?
Thanks in advance.
Thanks in advance.
I use bespoke events and variables to control vertical speed. The bespoke variable is so I can test it when it's zero to blank it out. The bespoke events use the standard sim/autopilot/vertical_speed_up and sim/autopilot/vertical_speed_down commands.
I've attached a zip of my configuration.
