Carenado's Citation II S550
Includes MCP-Pro, EFIS, and all my BeSpokes.
Doesn't cover everything (about 90%) and some items I double up to make work within the physical button/knob/switch count I have.
First cut, so maybe a few issues here and there S550 Files
The S550 was a little more complex than I thought it would be given it's only $45 aircraft. But weather radar works (gain, range, etc.), limited FMC but it works, EFIS is different but mostly works ... used Data for BRG cycle, Pos for EHSI cycle and STA for MAP/GFX cycle. Engine shutdown and startup took some testing but seems to work well with the MESM. Most of the SECM is mapped too.
As always backup your originals.
Cheers, Rob.
