A2A C182 and Aerosoft A320 configuration including MCP-Pro and EFIS
A2A C182
Note, requires A2A C182 Input Configurator to map the following
AP HDG = Ctrl + Shift + H
AP ALT = Ctrl + Shift + L
AP UP = Ctrl + Shift + U
AP DOWN = Ctrl + Shift + D
AP APR = Ctrl + Shift + A
AP NAV = Ctrl + Shift + N
Aerosoft Airbus
Both include "clean" (i.e. no other aircraft in the files) set of:
Settings.xml
BespokeVariables.xml
BespokeEvents.xml
[aircraft name].xml
[aircraft name]_GFMCPPRO.xml
[aircraft name]_GFEFIS.xml (airbus only)
These are not be perfect, some additional adjustments maybe required and they are primarily focused on my "available" GF modules. I don't have enought GF modules to emulate every button, switch, rotary.
Here is a quick video demo and test flight (best viewed in HD at full screen):
Many thanks to Steve M. and his excellent GoFlight Interface Tool.
Cheers, Rob.
Nice video Rob. Love what you have done with DIO - is that a self made front panel for DIO?
Great idea, I'll have to give that a go!
Hi gee8ch,
Load up your Airbus, go into the Settings tab of GIT and shorten the aircraft name to "Aerosoft Airbus". Click save settings and it should now work for all the Airbus family.
I'm using now P3Dv3 with GIT 2.1.16.0 and have a problem with the A2A planes. The MCP Pro Rotaries are working in the plane, but the digits at the MCP doesn't work. They only show zeros.
In P3Dv2.5 the MCP Pro work without problems.
Martin
Hi Martin,
I'll take a look later on in the week.
thank you in advance. I'm using the same setup for P3Dv2.5 with the A2A planes, but in P3Dv3 I can move the gauges at the plane, but the displays at the MCP Pro did not synchronize and show "0".
Sorry that I could not solve this problem on my own.
Best wishes,
Martin
Hi Rob,
The instructions to use GIT for the MJC Q400 are topics at the top of the forum.
