GIT don't work
2»
  • ok i'm waiting for that,thank you
    I built a test environment running Windows 10, FSX and GIT using the French language and GIT worked OK, so I no longer think its an issue with language.
    I'm suspecting something wrong with the GoFlight drivers. Can you remove all your GoFlight equipment from your PC and try running GIT and let me know what happens. If it works OK, add one piece of GoFlight equipment at a time to isolate what piece of hardware if causing the problem.
  • Hi Steve
    I'm just back from a long travel and i have re-install GF 2.28 and the new GIT 3.6.3.1 and now it work then i have plug GF LGTII,MCPPRO and GF EFIS : everything work perfect .
    When i plug GF-MESM the problem come back and it lock everything
  • I'll see if I can re-create the problem.
  • ok thank you
    On my side i have check when i open GIT first with GF LGTII,EFIS and MCPPRO it's ok and after i plug MESM,GIT work normally but MESM don't work
  • Hello and happy new year 2019
    I come back to see if you solve the problem to use MESM because i try again and he don't work??
    Andre
  • What happens if you only have the MESM connected and then run GIT? Also try renaming My Documents\GoFlight Interface Tool to something so GIT starts with no config files, then enable the MESM and try again.
  • Hi Steve
    I try renaming GoFlight Interface Tool,nothing appear on my screenn,then i plug only the MESM and i start GIT,everything in red light and GIT completely lock,i have to resart my computer then i have tested this way
    1-start GIT look like ok and then i plug MESM and it work perfect
    2-re start GIT with LGTII,MCPPRO and EFIS and everything look like ok again and then i plug MESM now everything work perfect
    3-Last test,i re-start GIT with all components plug including MESM and again everything lock,really strange
    Andre
  • Give me a list of all the GoFlight hardware you have so I can test at my end.
  • List of GF
    - MCPPRO
    - EFIS
    - LGTII
    - MESM
    Andre
  • Hi Steve
    No news after my last message regarding my MESM
    Andre
  • End of the week!
  • Hi Steve, let me join the discussion because I have exactly the same problem as André.
    I have an MCPPro, GF-RP48, 3 x GF-T8-2, GF-MESM, 2 x GF-166, GF-46.
    Everything works well when I do not connect the MESM. As soon as I connect it, everything freezes.
    I look forward to seeing if you have found this weekend the reason for this problem.
    Good day and best regards.
    Laurent
  • Hi Laurent did you check again with the new GIT release on 22th of february
    Andre
  • Hi Steve
    Like before, everything works well when I do not connect the MESM
    If i connect MESM,everything freeze and it's finish ,we have to restart
    Andre
  • Its not fixed yet, as I cannot re-create the problem.
  • Hi Steve
    No more news for the MESM because many friend in our team are waiting to buy the system and they don't want to be in front of the same problem?
    Andre
  • Hi Andre,
    I have been working with another customer with the same problem to arrange a remote debug session as I cannot re-create the problem, but he has let me down. If you are willing to do a remote debug session which may take up to 2 hours of your time, then please do the following:
    You will need to do this on your flight sim PC:
    - Download and install this VPN software (its free for up to 5 computers so don't purchase it): https://www.vpn.net/
    - Sign up for an account in the VPN software. Don't do anything else with it as I will log onto your PC and configure the VPN network.
    - Download and install this for x64: https://visualstudio.microsoft.com/downloads/?q=remote+tools#remote-tools-for-visual-studio-2017
    - Download and install https://www.teamviewer.com so I can access your PC remotely (again its free for personal use)
    - At the time agreed, start up Team Viewer and PM me your Team Viewer ID and password (obviously do not post this on the public forum, PM me!) and we'll see if we can get to the bottom of this.
    Let me know when its convenient to do it. I would prefer late afternoon GMT, say 4ish. No problem with weekends either.
  • Ok Steve ,i'm just back home and for sure i agree to connect with you.
    Already i have
    - Hamachi is installed and have an account
    - Teamviewer also is working
    - just i finish to download visual studio
    wich way is the best for you to pass my Id and password?
    Everything is ok just i go out again tomorow for some few days.
    I contact you on the way back
    Andre
  • Try to plug your GoFlight device in to a different USB port.
  • Just PM on this forum towards the end of the week or weekend.
  • Bonjour à tous.
    Je viens d'installer la dernière version 2.0.15.2 et je n'arrive toujours pas à faire que le MESM soit actif.
    Toujours le même problème, sans MESM tout fonctionne à merveille, avec tout se fige.
    Juste une autre question:
    Peut-on faire qu'au lancement de GIT, les modules connectés soit actifs par défaut car, à chaque fois je dois activer tous mes modules ?
    Merci pour votre aide et bonne journée.
    lolopilote
  • The MESM issue has not been resolved.
  • salut lolopilote
    Cela fait plus de 6 mois que ça dure et toujours pas d'issue pour le MESM,je pense que lorsque l'on vend un logiciel ou un materiel,on s'assure qu'il fonctionne avant de faire la transaction ce qui n'est pas le cas.
    Ou en est tu car j'ai été pas mal absent?
    Andre
  • Hi Andre,
    There is no fix, because no one has arranged followed through on a remote debug session. I cannot fix what I cannot re-create. If you want a resolution, lets agree a remote debug session so I can see what is going on.
  • Hi Steve, sorry but i'm out of my house from 3 months and i think i'm not back untill end of october.
    When i come back i agree to organize a debug session on my computer to fix this situation,i can do nothing before
    Best regards
    Andre
  • Hi Steve
    Could you purpose a date to organize a debug session on my computer to fix this situation
    Best regards
    Andre
  • Hi Andre,
    It will have to be next week, if that's OK.
  • Hi Steve
    Ok for next week but could you give me an zdvise the day before on my mail box : andreeymard@orange.fr
    Thank you
    Andre
