GIT - few questions
Hi guys - I'm new to GIT and after some reading and experimenting, have a few questions:
1. easy one first: my detective button is grayed out. Couldn't find why in the manual, any clue to that?
2. PMDG - is it possible to display the current set baro on the GF46? is that data available?
3. last one: is it possible to display "custom data" - i.e, if displaying autobrake selector position on GF46, instead of displaying the value (0-7), display RTO instead of 0 (ignore the 7segment limitation for a moment...) and "1" instead of the value 3?
Thanks in advance,
Ilan
    1) Detective is not available for PMDG aircraft as the PMDG SDK's are built in.
    2) I have had a look, but couldn't find anything obvious.
    3) No, the GF46 can only display numbers on the right panel.
  • Thanks Steve! yeah, I know the 46 is unable to display anything else, but is it possibe to display a number different from the real value accepted from simconnect?
    Again, using the example of autobrake: in the sim, the selector values range from 0-7, whereas 0=RTO, 1=Off, 2=disarm 3=1 4=2 5=3 6=4 7=max
    Forget RTO, disarm and off: is it possible to display "1" for autobrake level 1, when the value is actually 3? or can GIT display only the value itself?
  • There is no Light Action that can add or subtract a custom value so no. I will add it the dev plan though.
  • Thanks, much appreciated!
  • I've just got round to looking at this and there are Light Actions that subtract the custom value from the aircrafts value. Have you tried SUBTRACT_AS_INTEGER?
