GoFlight tool for X-Plane version 2.0.16.1: X-plane cannot find the win.xpl file
I deleted all evidence of the previous version of thhe tool (2.0.15.2) and have installed the new version. Both X-Plane and the GoFlight tool are set to run by Administgrtor as advised and a "GIT Plugin" folder is to be found in Resources\plugins. It contains two folders, 32 and 64 and inside 64 is win.xpl.
The log file from the tool reports "Pipe connection failed" repeatedly and the X-Plane log.txt file contains the following:
X:\X-Plane 11/Resources/plugins/GIT Plugin/64/win.xpl : Error Code = 126 : The specified module could not be found.
As I say, the 64/win.xpl file is apparently in place but for some reason X-Plane cannot "see" it. Anyone else having the same problem?
