INTERFACE 3.8.0.0
Senhores, estou usando o interface 3.7.0.1 e entrando em minha conta não sei como atualizar a interface.
Na minha conta em downloads só consta a chave. Nenhum arquivo a ser baixado. Por favor me orientem.
Obrigado
Obrigado
In my account in the downloads section, only the key appears and not the file I need. 3.8.0.0. Where can I download this file?
My system is P3D v4 and in my account the key is in the first option of fsx. I understand that it should be at the bottom where P3D v4 64bit is found. If the zip file is next to the key then there is something wrong available to me. My system is P3D v4 64 bits. Can you please verify that it is correct? How should I proceed to download the 3.8.0.0 zip file. Thanks.
If you check in My Account you will find that even if the key is in the wrong place (fsx instead of P3D v4 64 bits) beside it, the GIT zip download is unavailable.
Exact. Please tell me where can I download this file?
Inv # Files Expiry Left User key
2633
GIT FSX.zip
GIT FSX-SE.zip
GIT P3Dv4.zip
GIT P3D.zip
GIT P3Dv4 64Bit.zip
Never 0
Following the key that I did not copy here
