INTERFACE 3.8.0.0
Senhores, estou usando o interface 3.7.0.1 e entrando em minha conta não sei como atualizar a interface.
Na minha conta em downloads só consta a chave. Nenhum arquivo a ser baixado. Por favor me orientem.
Obrigado
  • In my account in the downloads section, only the key appears and not the file I need. 3.8.0.0. Where can I download this file?
  • "Orders, Downloads and Addresses. Click the Downloads tab and you will see your User Key listed next to your order and download options."
    My system is P3D v4 and in my account the key is in the first option of fsx. I understand that it should be at the bottom where P3D v4 64bit is found. If the zip file is next to the key then there is something wrong available to me. My system is P3D v4 64 bits. Can you please verify that it is correct? How should I proceed to download the 3.8.0.0 zip file. Thanks.
  • If you check in My Account you will find that even if the key is in the wrong place (fsx instead of P3D v4 64 bits) beside it, the GIT zip download is unavailable.
  • Exact. Please tell me where can I download this file?
  • I have just downloaded all the versions fine. 3.8.0.0 is only available for P3Dv4.
  • Steve, could you please provide the link, please, to download this file, since in my account it is not available. I ratify, my system is P3D v4
  • Can you attach a screen dump so I can see what is happening.
  • Inv # Files Expiry Left User key
    2633
    GIT FSX.zip
    GIT FSX-SE.zip
    GIT P3Dv4.zip
    GIT P3D.zip
    GIT P3Dv4 64Bit.zip
    Never 0
    Following the key that I did not copy here
  • edited April 2020
  • edited April 2020
  • edited April 2020
    I
  • edited April 2020
  • Ok, you needed your download count resetting. Try it now.
  • Bingo. Now in my account I have the icons for downloads. Thank you very much for the excellent help work, even with a language problem. Thank you very much
