CS757
Trying to get CS757 GF EFIS and MCP PRO working but having no success. Window light up but nothing works. Seems to be loading OK, three greens.
I have attached the log. Would certainly appreciate any assistance. Thanks
  • Check the devices are enabled. Check you have events and variables assigned to each of the controls. Check that Bespoke Events exist in Detective.
    No log attached?!
  • I have re-attached the log. devices are enabled (first thing I checked after looking through the forum) I far as I can tell the event do exist in detective.
  • Just in case, can't see if the log is attached or not
    11:29:08 GoFlight Connection Starting.....
    11:29:08 SimConnect Connection Starting.....
    11:29:09 SimConnect Message Processing Started
    11:29:09 GoFlight Connection Started
    11:29:09 SimConnect Connection Started
    11:29:09 Aircraft Connection Starting.....
    11:29:09 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    11:29:09 SimConnect: Event Received: SIM, 1
    11:29:09 SimConnect: Event Received: PAUSE, 0
    11:29:12 WinSock: Connected To localhost On Port 27015!
    11:29:12 LUA Processor: Started!
    11:29:16 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
    11:29:16 Aircraft Connection Started
    11:29:16 Simconnect Version: 3.4.0.0
    11:29:16 Aircraft FullName: CS_B757-200-III_RB535E4_4D
    11:29:16 Synchronising Switches & Selectors .....
    11:29:16 LvarNamesUpdated!
    11:29:16 Creating Bespoke Vars
    11:29:16 Bespoke Vars Created
    11:29:16 Importing Bespoke Variables
    11:29:16 Bespoke Vars Assigned, Importing Bespoke Events
    11:29:16 Bespoke Events Temp Imported
    11:29:16 Bespoke Events Imported
    11:29:16 Loading Aircraft Settings
    11:29:16 GetXMLConfigData
    11:29:16 GotXMLConfigData
    11:29:16 Loading Power
    11:29:16 Loading MCPPRO
    11:29:16 Loading EFIS
    11:29:16 Loading P8
    11:29:16 Loading T8
    11:29:16 Loading RP48
    11:29:16 Loading MESM
    11:29:16 Loading WP6
    11:29:16 Loading LGT
    11:29:16 Loading LGT II
    11:29:16 Loading GF46
    11:29:16 Loading GF45
    11:29:16 Loading TQ6
    11:29:16 Loading DIO
    11:29:16 Loading GF166
    11:29:16 Loading SECM
    11:29:16 Loading Joysticks
    11:29:16 Clearing Displays
    11:29:16 Reset Data
    11:29:16 Aircraft Settings Loaded
    11:29:16 Calling Aircraft Changed
    11:29:18 Aircraft Changed
    11:29:18 LvarNamesUpdated!
    11:29:18 Creating Bespoke Vars
    11:29:18 Bespoke Vars Created
    11:29:18 Importing Bespoke Variables
    11:29:18 Bespoke Vars Assigned, Importing Bespoke Events
    11:29:18 Bespoke Events Temp Imported
    11:29:18 Bespoke Events Imported
    11:29:18 Loading Aircraft Settings
    11:29:18 GetXMLConfigData
    11:29:18 GotXMLConfigData
    11:29:18 Loading Power
    11:29:18 Loading MCPPRO
    11:29:18 Loading EFIS
    11:29:18 Loading P8
    11:29:18 Loading T8
    11:29:18 Loading RP48
    11:29:18 Loading MESM
    11:29:18 Loading WP6
    11:29:18 Loading LGT
    11:29:18 Loading LGT II
    11:29:18 Loading GF46
    11:29:18 Loading GF45
    11:29:18 Loading TQ6
    11:29:18 Loading DIO
    11:29:18 Loading GF166
    11:29:18 Loading SECM
    11:29:18 Loading Joysticks
    11:29:18 Clearing Displays
    11:29:18 Reset Data
    11:29:18 Aircraft Settings Loaded
    11:29:18 Calling Aircraft Changed
    11:29:19 Aircraft Changed
    11:29:19 Synchronising Switches & Selectors Complete
  • I will PM the person who developed it to make sure it still works. Sometimes the developers update the aircraft and everything changes.
  • Understood. Thanks
