Slow LED response GF-MCP Advanced Autopilot
I am running the GF-MCP Advanced Autopilot on my PMDG 737 NGX, everything working ok except that the LEDs are very slow to respond when turning the knobs on the MCP module. The LEDs in the SIMs Virtual Cockpit updates immediately but the LEDs on the GF-MCP module take a few seconds to update. The same thing happens whether I dial the setting from the SIM or the module. It's as if the command is going TO the SIM fast enough but the signal coming back from the SIM is slow. Anyone experienced this before?
Also check the Log tab for any errors that are firing when you turn the rotaries on the MCP.
Also, does the MCP update slowly if the MCP in the Virtual Cockpit is used to change values?
Thank you very much for your reply. I will try changing the setting as you suggest.
In answer to your question, the MCP does also update slowly if I adjust in the VC.
I have noted a marked improvement since plugging the USB cable directly into the PC instead of via a powered HUB, but I am now experiencing lock ups in the display after say 10 minutes into a flight - all LEDs in displays and buttons freeze, but the dials and buttons still update the Virtual Cockpit very quickly. I have to completely restart everything to get it working again, even pressing restart in the GIT doesn't have any effect.
I will start observing the log to see whats going on as well.
Many thanks for the tips, I will report back soon.
Problem solved! Having followed your suggestion I set Write delay and CMD delay to zero on Both the MCP tab and the Settings tab and I have had no lock ups at all. Displays still responding nicely as well. When I reloaded the GIT later I noticed that it did not save the zero values in the settings tab but did save them in the MCP tab, but I still did not experience any problems, therefore it seems the only critical adjustment needed was setting the MCP values to zero.
Thank you very much for your prompt assistance, you have saved me a lot of frustration and sleepless nights :-)
Kind regards,
Mark
It's GoFlight that state no USB3.
