Suddenly P3D crashes at startup when GoFlight Interface Module is enabled
Without any (obvious) reason, I cannot start P3D (v2.4, on Windows 8.1) anymore. I get a Fatal Error occurred before the splash screen disappears. See event logs below.
Even when I disabled all other plugins (in dll.xml and exe.dll), P3D crashes. I get a consistent crash when GIT is enabled, and get P3D to start when GIT is disabled. I tried a lot of combinations, put GIT as first module, but to no avail.
I also did a "repair" using the GIT installer. No luck either.
Can you give me and advice, or is there more information I can send you to track down the problem?
Thanks!
Emile.
Here are the two relevant entries of the Application Log, one error, one information:
--ERROR--------------------------------------------------------------------------------------
Faulting application name: Prepar3D.exe, version: 2.4.11570.0, time stamp: 0x542314d3
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0000e96e
Faulting process id: 0x140
Faulting application start time: 0x01d047b91a96aada
Faulting application path: C:\Program Files (x86)\Lockheed Martin\Prepar3D v2\Prepar3D.exe
Faulting module path: unknown
Report Id: 5e57d95d-b3ac-11e4-8263-448a5bd065dd
Faulting package full name:
 ----------- INFORMATION ----------------------------------------------
Fault bucket 81809558003, type 5
Event Name: BEX
Response: Not available
Cab Id: 0
Problem signature:
P1: Prepar3D.exe
P2: 2.4.11570.0
P3: 542314d3
P4: unknown
P5: 0.0.0.0
P6: 00000000
P7: 0000e96e
P8: c0000005
P9: 00000008
P10:
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\Prepar3D.cfg.txt
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\dxdiag.txt
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\scenery.cfg
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\fdr.dat
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\DLL.XML
C:\Users\Emile\AppData\Local\Temp\WER8400.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\Emile\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_Prepar3D.exe_81657ca19d16f9339eb25d7676739311db855de_00000000_1a338bef
Analysis symbol:
Rechecking for solution: 0
Report Status: 1
Hashed bucket: f3e729fd693b63874dcc8a1a8df25f11
