Suddenly P3D crashes at startup when GoFlight Interface Module is enabled
Without any (obvious) reason, I cannot start P3D (v2.4, on Windows 8.1) anymore. I get a Fatal Error occurred before the splash screen disappears. See event logs below.
Even when I disabled all other plugins (in dll.xml and exe.dll), P3D crashes. I get a consistent crash when GIT is enabled, and get P3D to start when GIT is disabled. I tried a lot of combinations, put GIT as first module, but to no avail.
I also did a "repair" using the GIT installer. No luck either.
Can you give me and advice, or is there more information I can send you to track down the problem?
Thanks!
Emile.
Here are the two relevant entries of the Application Log, one error, one information:
--ERROR--------------------------------------------------------------------------------------
Faulting application name: Prepar3D.exe, version: 2.4.11570.0, time stamp: 0x542314d3Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0000e96e
Faulting process id: 0x140
Faulting application start time: 0x01d047b91a96aada
Faulting application path: C:\Program Files (x86)\Lockheed Martin\Prepar3D v2\Prepar3D.exe
Faulting module path: unknown
Report Id: 5e57d95d-b3ac-11e4-8263-448a5bd065dd
Faulting package full name:
----------- INFORMATION ----------------------------------------------
Fault bucket 81809558003, type 5Event Name: BEX
Response: Not available
Cab Id: 0
Problem signature:
P1: Prepar3D.exe
P2: 2.4.11570.0
P3: 542314d3
P4: unknown
P5: 0.0.0.0
P6: 00000000
P7: 0000e96e
P8: c0000005
P9: 00000008
P10:
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\Prepar3D.cfg.txt
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\dxdiag.txt
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\scenery.cfg
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\fdr.dat
C:\Users\Emile\AppData\Roaming\Lockheed Martin\Prepar3D v2\DLL.XML
C:\Users\Emile\AppData\Local\Temp\WER8400.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\Emile\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_Prepar3D.exe_81657ca19d16f9339eb25d7676739311db855de_00000000_1a338bef
Analysis symbol:
Rechecking for solution: 0
Report Status: 1
Hashed bucket: f3e729fd693b63874dcc8a1a8df25f11
Have you installed the PMDG 777 into Prepar3d? If you have it breaks GIT and I'm still investigating the issue. See http://www.pollypotsoftware.org.uk/support/forum.html#/discussion/167/pmdg-777-for-p3d-v2-5-pmdg-dll-xml-entry-will-prevent-git-from-working-correctly
Hi Emile.
If you haven't installed any other scenery or aircraft recently then I suggest reinstalling GIT.
I'm seeing this problem now in FSX. I noticed a load of Windows updates happened for me yesterday so I think it must have something to do with those. I'll investigate.
The windows update could very well be the problem indeed. I remember that I got an update too. I'm not 100% sure that was the breaking point but might be.
Thanks!
-Emile.
Ok, found the issue:
1) Open regedit
2) Goto the key HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
3) Delete the key "C:\\Games\\FSX\\fsx.exe"="$~ RUNASADMIN IgnoreFreeLibrary<Goflight Interface Module.dll>" obviously changing the text in bold to be your flight sim version and its location.
Yes, that solved the problem. Wow, I'm impressed with your quick response.
Best regards,
Emile.
Great. It took me hours to track that problem down!
