P3 D v5 and MCP Pro
Hi there
I just purchased GIT software and trying to set up with Go flight mCP pro. I have been using the older version for FSX successfully for many years. It seems I don’t have the appropriate “bridge” software in my go flight folder for v5 . Am I missing something ? It only has v4? It seems the sim is picked up on the GIT software with all three lights being green however the mCP has only dashes on the display. I appreciate any support here thanks !
could not find part of the path
C\users\app data\roaming\locheed martinprepar3Dv4\dll.xml
Thanks for your assistance
AS
<Launch.Addon> <Name>GoFlight Interface Module</Name> <Disabled>False</Disabled> <ManualLoad>False</ManualLoad> <Path>C:\Program Files\GoFlight\GoFlight Interface Module 64.dll</Path> </Launch.Addon>If the dll.xml file isn't there, create it and add all this:<?xml version="1.0" encoding="Windows-1252"?> <SimBase.Document Type="Launch" version="1,0"> <Descr>Launch</Descr> <Filename>dll.xml</Filename> <Disabled>False</Disabled> <Launch.Addon> <Name>GoFlight Interface Module</Name> <Disabled>False</Disabled> <ManualLoad>False</ManualLoad> <Path>C:\Program Files\GoFlight\GoFlight Interface Module 64.dll</Path> </Launch.Addon> </SimBase.Document>Change directory paths as necessary!Best wishes
Thank you for your assistance!
