With Daher 000 and no change turning dials
Where is the log file of GIT?
On my end, I am (very) happy to report that I finally understood everything.
Modules work great in P3D and, slowly, getting to know the GIT in MSFS202.
Have a great weekend!
Many regards
Roberto
I have accidentally pressed button default-FS right to Button V-Nav + device 0 enabled
and it works with Daher, 747 and 787 !!!
and good news also with Airbus ????
I do not understand why but I will remember the way.
The good way after loading an aircraft = reload GIT, set device 0 enabled
Is there a way to record the right parameters in the settings?
You should write a short memo for FS2020 indicating the few steps to get it
Best regards
I have the GF166a vrp, GF-MCP, GF-p8 and GF-t8.
-> Do not install the older version and if installed remove it, its not needed if all you have installed is MSFS2020
Once you install this software you should start MSFS2020 and then get the aircraft at a starting point.
Now you should be able to start this software up, and on the status page you should have 3 green buttons
Have you got this far?
Please read the Beginners Guide mentioned in this thread. There are no profiles for FS2020 yet. For your MCP PRO, all you need to do is start up the sim and get the VC showing. Load GIT, select the MCP PRO tab and select Device 0 from the drop down. Click the FS Default button and then Enable the MCP PRO via the drop down (ENABLED). Quit GIT and restart and your MCP PRO will work.
For example, coarse settings (10's in heading/course and 1000's in altitude) are set using the mouse scroll wheel.
Fine settings (single values) are set using the left and right mouse buttons (my right button is not being recognized (??), but that is another story).
The GoFlight MCP is not consistent when changing the rotary values (course, speed, heading, altitude, V/S) and as you turn a rotary, the values increase finely or coarsely in an unpredictable manner.
Tried it in the Carenado C182 and the default B747 with the same results.
Roberto
I'll try and find a work around in GIT in the meantime.
