Fs 2020 and go flight blues for sure
so i dl new update interface for fs2020 it worked for a few days ( radios only) AND now nothing at all.. also gf-tq6 throttles only working in reverse.. i have click the dam reverse button A ton of times now and save works great till you touch throttle then they revert back to the wrong direction.. I have messed with it for hours now and give up,,, Will goflight product ever work with fs2020 or is it time to sell this old stuff and start over??????? any suggestion here would be great full
Jeff R.
  • Your need to make sure your GF166's are not locking up, they are very finicky. You can double check, by loading up FSX or P3D and using GoFlights drivers to make sure they are actually functional at a hardware level. If they are and they still don't work in FS2020, please post your GIT log so I can track down the issue.
    As for the TQ6, are you using GIT to configure it or FS2020? If you are using GIT, I will look into the issue as no one else has reported a problem, but perhaps a bug has crept in. In the meantime, you could configure the TQ6 axis in FS2020 directly.
  • lol theres a whole lot of computer talk.. You lost me at GIT.... sorry im not a computer tech guy at all. I have DL new goflight drivers and yes it sees go flight products but not see any FS2020 installed.. Yes they worked before i deleted p3d.
  • I have spent a few hour now and baam.. things are coming together i have throttles working in correct direction and LGT working. programmed a few buttons on the t8 rp 48 and 1666 radios.... How ever setting wont save and then reload after a re boot. i hit the save setting but noting happens...what may i be doing wrong or do you need to program after each reboot. ? FS2020
  • Have you followed the steps in here: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1436/fs2020-feature-status-and-usage#latest
    Each aircraft needs to be configured.
  • Thanks again Steve that was a big help..got it working and saving.. Import worked...
  • Can somebody please tell me how to program The T8 ??????
