T8 Programming help
Please tell me how to program The T8 !! I am LOST !!
However I would strongly suggest you read the user guide from the beginning here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git.html
The Beginners Guide in the user guide also contains some video links.
On a switch, with the Switch Event ON select the TOGGLE_MASTER_BATTERY event. Then change the Switch Event to OFF and select the TOGGLE_MASTER_BATTERY event. The Switch Action and Custom Values options can be ignored, so make sure they are set to NOTHING for ON and OFF and 0 respectively.
For the LED, set the Light Data to ELECTRICAL_MASTER_BATTERY with a Light Action of ON and a Light Value of 1.
Tried to get avionics to work I couldnt get it to work
Also Eng1 Start/run cut......Eng2 Start/run cut
