Updated GoFlight P3Dv4.5 64bit and will not work now?
I was on the forum last week, I updated to the 64bit P3Dv4.5 version and cannot get my GoFlight to work. When I look at the log file it says:
SimConnect: ExceptionReceived: DUPLICATE_ID
Please see attached picture
Thanks Laurie
Thanks Laurie
https://www.pollypotsoftware.org.uk/vanillaforums/discussion/674/gfit-p3dv4-simconnect-exception-received-duplicate-id
https://gyazo.com/4f4c8c42a06c2a07b32144c0a3204d6a
https://gyazo.com/ca0b5d84facc75da3a68408bcc5703ec
Can't recall seeing this folder before
Laurie
I have just tested with P3D and GIT 3.8.1.0 with a clean config and found no problems at all. Did anything else change on your system when you updated GIT? You are installing the 64bit version into Program Files and not Program Files (x86)? Do the errors remain if you install the prior version back?
Sorry caps lock on
