I have the GF 166A VRP and the GF-46 models I can't configure it.
follow the steps of https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1436/fs2020-feature-status-and-usage
but I can not configure it does not show anything nor does it turn on
I appreciate the help
att
yaco
att
yaco
the other components if they work and the light turns on for example the mcpro, LGT, T8 and gf8
I restart the GIT and nothing that lights up, what could it be?
if it worked with other simulators example p3dv4 currently uninstalled my p3dv4
2.- Does the identify button produce anything on the devices?
when you move the knobs, the numbers move in msfs2020 but in the device the number LEDs do not light up or light up
Br.
Erwin
Guess what, everything is working now.
All my switches on T8 work. Lights go on and of when right configured.
Also on P8 everything works.
LGT works. Lights are green and turn red when gear is up.
MCP works, lights and rotaries Okay.
GF166 are working on nav or com. Default settings are Okay.
GF46 is working with the TBM930, although not on Cessna 152. Maybe because it’s not present in the C152?
So I am happy with this piece of software.
If you are in doubt, don’t be. Just buy this great piece of software!
Br. Erwin
