GF TQ6 configuration
Hello
What is the best way to configure the GF TQ6 with P3D and 737 NGX : FSUIPS or GÎT
If I use GÎT , the procedure is automatic ? I must click défaut pmdg /IFLY ? Or I Must configure axes ?
For the reverse , where are the settings ?
Thanks for your help
Phill from France
Phill from France
There is no advantage either way. If you are familiar with FSUIPC, use that or not. There is a guide under the Support section for configuring the NGX with FSUIPC or see this if you want to use GIT: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/36-configuring-goflight-devices-additional-information-pmdg-ngx-77x-747x.html however you will need to tweak the results as each TQ6 is slightly different.
Thanks for your reply, we can always count on you !
Sorry i had Forgot To consult the online help
I Will try To configure m'y TQ6 with GÎT
Phill
