Active lights of MCP Pro are going out when rotary knobs are used
I have just obtained a MCP Pro and EFIS. I'm using this together with the newest version of the PMDG NGXu under P3D v4.5.
The GFConfig Software has been installed and operation mode has been set to "compatible add on".
Everything is working fine except one annoying thing.
Every time I use a rotary knob (e.g. Altitude, Heading or Speed) all active lights go out on the goflight hardware although they are active in the PMDG 737.
Active lights are for example A/T ARM, F/D, LNAV; VNAV and so on.
When I click any button like for example LNAV, VNAV etc. after the lights went out the lights come up again on the hardware.
I really hope there is a fix for this!
Thank you so much!
Best regards Andi
Thank you so much!
Best regards Andi
As soon as I'm closing the Spad.Next software it is working fine.
That is however no solution for me. I need Spad.Next for my Saitek Radio Panel. Is there any chance to get both software working without interfering each other?
I'm using only standard settings under the GIT tool and the Spad.Next software.
Looking forward to a fix!
Thank you!
