GF-T8
The GF-T8 does not work. The switches do not function On Off and the LED do not light up.
Greetings Peter
Greetings Peter
Thank you
Yes, I have activated GIT.
For example, if I want to activate a switch for beacon lights for on and off, it doesn't work. The control light is also not on. It would be normal to switch to the front "beacon on" with light. Switch back "beacon off" light off.
it would be possible to send me the settings as an example.
greet Peter
Thank you very much for the XML file. It works for me too. Only the alternator lamp is always on. But I can live with that.
I also have problems with the GF-166. Could you also send me the XML file for this device? It would be a great relief for me.
Greetings from Switzerland
Peter
Peter
For the GF-166, just click the NAV, COM or ADF buttons on the GF-166 tab and then enable the device as per above.
The GF-166 works right out of the box. i.e. with the file provided by steve.
Best regards from the Netherlands
Erwin
Peter
I will try to replicate your settings in the coming weekend.
Best regards,
Erwin
Could you possibly send me printscreen from your settings or the XLM file. It is despairing. I can't get any further.
Thank you Peter
