Issues after P3D v5.1 Install
Hello Steve:
I did a full uninstall of P3Dv5.0 followed by a full install of P3Dv5.1.
I uninstalled and installed the two PMDG aircraft (B737NGXu and B747 QOTS II) and their expansions.
I now have an issue related to those aircraft, with the MCP-Pro and two of my T8's.
The MCP-Pro shows only zeros, however, the respective windows in the simulator, work OK, when I turn rotaries or press buttons.
The two T8's have all their lights lit and do not work at all.
My other devices
One more T8
Two RP48's'
EFIS
GF-45
GF-TQ6
GF-LGT II
Are wotking exactly the way I had them working in P3Dv5.0 (I did not have to re-porgram them)
I have tried the suggested solutions in the FAQ's regarding the MCP-Pro zeros, without success.
I know that there might be issues related to the updated simulator, that might be affecting my set up.
Any advice, as always, is greatly appreciated.
Many regards,
Roberto
  • I just forgot to add, that when I start GFIT, I get the following message:
    "PMDG options file updated, if a PMDG aircraft is loadedin Prepar3D v4, please unload it and reload it!"
    But I don't have v4 of the simulator installed.
    Roberto
  • Hi Roberto,
    The message is valid, I have simply forgotten to update it for v5. Quit QIT and the P3D and restart and it should be fine.
  • Thank you Steve!
    Did all that, and all is well.
    Roberto
