T8 - LEDs won’t light with Identity
Hi Steve, running P3D v4.5 and using GIT 64-bit. Strange problem when associating commands to a new aircraft - Vertx Diamond DA62.
I’ve programmed all but one switch on a T8 module and the relevant commands are correctly associated with each one but they don’t do anything in the aircraft. Also, the Identify command should cause all LEDs for the module to illuminate but they remain off.
My other T8 is fine but that has default P3D commands on it. I’ve rebooted but the problem remains. If I switch to the Cub the Identify command does light up the LEDs which suggests there’s a problem between that aircraft and my programmed switches. Can you offer a solution please?
Ray (Cheshire, England)
    I've found and fixed the problem. I exported the settings for both my two T8 units and on looking at the XML files I noticed Brightness for the troublesome one was set at 0. The other one was set to 8. So I changed the problem one to 8 and Identify now illuminates the LEDs.
    I love simple solutions! :)
