PMDG 737 BBJ
Hi there I have been using the Pollypot software for MCP pro successfully with PMDG 737 NGXU within p3dv5, however I have just purchased their latest expansion pack (BBJ) and unfortunately it no longer works. I was told by PMDG the following:
“ Did you contact the developer of the hardware? They might need to adjust their software as there are changes to accomodate the BBJ in the SDK”.
Not sure what is required and would appreciate any support.
Alex
  • Hi Alex,
    Thanks for the heads up! If the SDK has been changed, GIT will not work with it. I will look into it shortly.
  • Yep what Alex said....Thanks Steve.
    Ben
  • Thanks guys look forward to seeing the update
  • Steve any news here? I am also holding off updating to P3dv5.1 until I know this will all work thx
  • Hi Alex.
    In my set up, with a full installation of P3Dv5.1, the only PMDG aircraft that GFIT is not working on is the B737BBJ, for which Steve will eventually give us an update.
    For my other PMDG B737NGXu's (including the cargo version) and the PMDG B747's, GFIT is working.
    Roberto
  • Thanks Roberto. Once you updated to 5.1 did you need to do anything to the GFIT or did it work straight away. Just hesitating an upgrade and trying to get everything working again ! Appreciate your reply.
  • Hello Alex.
    GFIT started working in v5.1 on the aircraft I listed above, without me having to do anything.
    But I have to be honest. That full install update to v5.1, brought me quite a few issues. Maybe only a Client one is sufficient.
    ActiveSky is still not working and takes away a lot of the realism I like.
    I spent a long time installing, veryfing, etc. etc. with my many ORBX sceneries. I haven't checked yet if that worked.
    The truth is that I should have waited to make sure that the hotfixes (there always are some) have been posted.
    I am not one to "go back" to previous versions, so I'll "live with it" in the meantime.
    So, if you are hesitant about installing v5.1 I'd suggest you wait a couple of weeks and save yourself some of the frustrations I am going through.
    Roberto
  • Just to add to my post above, HiFi Simulations (makers of ActiveSky) just found a walk around the restrictions of P3Dv5.1 and released an update that is working with the sim.
  • Hey Roberto thanks for sharing. Very good advice I may wait a couple of weeks. Hope you have a great weekend!
  • Hey Steve are we any closer to a fix here ? Thanks !
  • Yep what Alex said...Thanks Steve.
  • Hey Steve.
    I have a problem...I just can't fly anymore without my MCPro...really waiting for the fix buddy.
    Guess this is a low priority item. My corporate clients are not happy with me...
    Ben
  • Thanks Steve a fix would be great 👍
  • It's pencilled in for this week assuming I get to a logical point to pause alpha testing.
  • Great news, Steve!
    I am sure you’d have many volunteers for any beta testing!
    Looking forward to get and install it.
    Thanks!
    Keep safe
    Roberto
  • Likewise!
  • All done! Download in the normal way.
  • Yay!!!
    As my grandkids would say.
    Thanks Steve
    Roberto
  • Thanks Steve!!
    Ben
  • Amazing thanks!
  • Sorry guys in all of my excitement I don’t know how to get it working ! I just went back in and downloaded the GIT software and added purchase key but doesn’t seem to work. I am clearly doing something wrong 😑
  • Check the version, it should 3.8.2.0
  • All good guys I downloaded the wrong one! Happy days 😁
