MCP Pro doesn`t work
i have a little problem with my MCP Pro (P3D v4.5):
i installed the latest GF Driver form GF Homepage today. Set it to compatible addon.
Then i installed the Pollypott Software.
After import the profile for Dash8 into my wizard the altitude digits shown 4300ft at every time (Dash8 Q400 Pro 64bit). if i change the altitude with the goflight knob, i can see some changes but after that the digits shown 4300ft again. The Pollypott software shown all is ready (green).
Then i tested it with a generic aircraft (mooney bravo glass cockpit). No knobs are working.
Again with the C130J-30 - it doesnt work. Pollypott Software identified generic aircraft C130J-30.
I think i need a little help...
  • Double check you have set compatible add-on the tab for your version of the flight sim.
    With default aircraft, click the FS Default button on the MCP PRO tab, make sure its enabled, then quit GIT and restart it.
  • i will check it again... Thank you...
