MSFS 2020 and LGT11
Hi, I have run the GIT FSX with MSFS it originally had 3 green lights and the aircraft was recognised as Asobo_A320_NEO, however it now has a yellow light under SimConnect.
Do I need to buy another version of GIT to run with MSFS?
Copy of current log
16:46:40 SimConnect Message Processing Finished
16:46:40 GoFlight Connection Starting.....
16:46:41 SimConnect Connection Starting.....
16:46:41 GoFlight Connection Started
16:46:42 SimConnect Message Processing Started
16:46:42 SimConnect Connection Started
16:46:42 Aircraft Connection Starting.....
16:46:42 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:46:42 SimConnect: Event Received: SIM, 1
16:46:42 SimConnect: Event Received: PAUSE, 0
16:46:42 SimConnect: Exception Received: UNRECOGNIZED_ID
16:46:43 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:47 WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
16:46:47 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
16:46:51 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
16:46:51 Aircraft Connection Started
16:46:51 Simconnect Version: 10.0.61259.0
16:46:51 Aircraft FullName: Asobo_A320_NEO
16:46:51 Synchronising Switches & Selectors .....
16:46:51 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:52 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:53 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:54 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:55 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:56 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:57 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:58 SimConnect: Exception Received: OUT_OF_BOUNDS
16:46:59 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:00 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:01 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:02 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:03 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:04 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:05 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:06 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:07 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:08 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:09 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:10 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:11 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:12 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:13 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:14 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:15 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:16 SimConnect: Exception Received: OUT_OF_BOUNDS
16:47:20 Synchronising Switches & Selectors Complete
Copy of current log
The LGT Tab has nothing in Device DISABLED in the second box and the following Log
Is there something I am not doing correctly?
19:54:56 GoFlight Connection Starting.....
19:54:56 SimConnect Connection Starting.....
19:54:57 SimConnect Message Processing Started
19:54:57 GoFlight Connection Started
19:54:57 SimConnect Connection Started
19:54:57 Aircraft Connection Starting.....
19:54:57 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
19:54:57 SimConnect: Event Received: SIM, 1
19:54:57 SimConnect: Event Received: PAUSE, 0
19:54:57 SimConnect: Exception Received: UNRECOGNIZED_ID
19:54:58 LvarNamesUpdated!
19:54:58 Creating Bespoke Vars
19:54:58 Bespoke Vars Created
19:54:58 Importing Bespoke Variables
19:54:58 Bespoke Vars Assigned, Importing Bespoke Events
19:54:58 Bespoke Events Temp Imported
19:54:58 Bespoke Events Imported
19:54:58 Loading Aircraft Settings
19:54:58 GetXMLConfigData
19:54:58 GotXMLConfigData
19:54:58 Loading Power
19:54:58 Loading MCPPRO
19:54:58 Loading EFIS
19:54:58 Loading P8
19:54:58 Loading T8
19:54:58 Loading RP48
19:54:58 Loading MESM
19:54:58 Loading WP6
19:54:58 Loading LGT
19:54:58 Loading LGT II
19:54:58 Loading GF46
19:54:58 Loading GF45
19:54:58 Loading TQ6
19:54:58 Loading DIO
19:54:58 Loading GF166
19:54:58 Loading SECM
19:54:58 Loading Joysticks
19:54:58 Clearing Displays
19:54:58 Reset Data
19:54:58 Aircraft Settings Loaded
19:54:58 Calling Aircraft Changed
19:54:59 Aircraft Changed
19:54:59 WinSock: Connected To localhost On Port 27015!
19:54:59 LUA Processor: Started!
19:54:59 Aircraft Connection Started
19:54:59 Simconnect Version: 11.0.62651.3
19:54:59 Aircraft FullName: Asobo_A320_NEO
19:54:59 Synchronising Switches & Selectors .....
19:55:01 Global LUA Event Running
19:55:01 Global Aircraft LUA Event Running
19:55:01 Synchronising Switches & Selectors Complete
It solved all my problems
