LIGHT ACTION
I don't understand why my light actions don't work : the green light of all of my modules don't turn on when i programm a event
but the light works when i identify a module
for example
switch event : on evt ch fuel pump 2 aft
switch action : onoff reversed
lightdata data : fwdoh fuel low press aft right
light action : on light value : 1
Thank for your help
Phill26 from France
for example
Thank for your help
Phill26 from France
Thank you for your reply
currently I try to configure the 737 ngx under p3dV4.5
I have a new problem to assign the start levers with the push buttons of the RP48 module
I can't find a valid action
switch event : evt control stand eng1 start
switch action ?
light data : data cl std switch eng start valve left
action : off light value 1
have you got an idea ?
thank again
Phill26 from France
Ok
When N2 reach 25%
Engine lever Cut of to idle
I undestand the process much better
Thank a lot again
