Prepar3D4 v5.1/PMDG 748
I have downloaded and installed v3_8_1_0 (GITv4v5). The displays on the GFMCP Prop are corrupted. I am able to change the heading and it matches the MCP in the PMDG 748. However, the MCP Pro do not display the correct IAS/Altitude and VSI values. I checked the documentation, but the problem remains. The dll.xml is correct and references the GF Interface Module 64.dll. The GFConfigSetup is v2.28.0.2. As an example, the Altitude on the 748 is 11500; the MCP Pro displays 01500. The IAS is 215, and on the MCP Pro it is 015--Could this be a USB3 issue? Thanks--
