Add Aircraft
Hello Steve
With the C172 (MSFS) all lamps light up. However, when I switch to the caravan, everything stays dark. However, the caravan is displayed in the GIT and all 3 lamps light up green. Default button does not work. And the import does not work because a zip file is required there. But in MSFS I don't have a zip file because the plane is standard.
Thank you very much for your help
Peter
Peter
It's either because you haven't enabled your hardware in GIT for this aircraft or because the aircraft is not standard Simconnect compliant. The FS SDK may have specific new variables that this aircraft uses, but the FS SDK isn't finished yet.
