Problem: X-Plane 11.50 crashes when activating GFIT - Detective
After using GFIT for FSX and P3D4.5 for a few years, I recently purchased GFIT for X-Plane, as I want to program my GoFlight modules for the FF B767. Started using Detective, programmed a few bespoke events, assigned those to a few buttons/rotaries on a RP48. So far, so good.
Unfortunately, every time I now want to use Detective from GFIT, XP11.50 crashes (CtD, askes whether I want to send an error report). Any ideas on what causes this, and what I can do to repair it?
Thanks in advance, regards,
Bert
  • To see if there is a corrupt file at play, try renaming Documents\GoFlight Interface Tool. You will temporarily lose your config data, but see if Detective starts up.
  • Thanks for your reply. Have been ill for about a week, so couldn't check.
    Before trying out your suggestion, I took advantage of an update of the FF B767: after the update it worked as before. Unfortunately, this didn't last long: as XP11 was running together with Detective for the B767, I switched to the FJS B727 (might have been the other way around): and again, XP11 crashed. Restarting XP11 and Detective for B767: again, an XP11 crash.
    Then I tried your suggestion: and indeed, Detective started up and XP11 kept running. Problem of course was loss of config data; when I tried to put (part of) it back: again crashes.
    Using Detective with the FJS still worked, so I started programming functions for the CIVA INS. Worked well, till I tried to program a 'Call' on an MSU decrease command: GFIT crashed, XP11 kept running. Restarting GFIT resulted in a crash of XP11. I restarted XP11, then GFIT: it works again, but I lost work of about an hour.
    I'm not sure what the problem is. I'm using GFIT for P3D with PMDG B737 and B747 quite extensively, and never encountered a problem; the difference might be that with PMDG I don’t use Detective. For some reason, in XP11 it's quite 'nervous'; and like this it's neither much fun nor very useful.
    I hope you have a solution for the problem. Thanks in advance for your reply.
    Regards, Bert
  • Is it only crashing with 3rd party aircraft?
  • It crashes with the FlightFactor B767 and the FlyJSim B727. I haven't tried with standard aircraft, as I'm not planning in using those.
  • edited December 2020
    It's working now, more or less, with the B727. I'm saving my commands and assignments every few minutes. Even then, I lost some of those after a session. It means I'm always hoping it won't crash (again). Haven't tried again with the B767, as the last time I tried XP11 crashed immediately
  • It shouldn't be doing this. I will look into it after the xmas break to try to get to the bottom of why these 2 aircraft are causing issues.
