Problem with GoFlight MCPPro and Pollypot Software
i have a big problem in chrsitmas time....
My MCPPro doesn`t work with PMDG NGX.
I`m using it with P3D v4.5 and PMDG NGX not NGXU. (Otion . ini is correct like the FAQ discribed)
Iìnstalled the GoFlight config tool (2_28_0-29) into C:Programme/Goflight.
Into the same folder i installed the pollypot Software.
After the pc machine restart, i start the GF Config exe and set the MCPPro to compatible Addon.
After that i finished the *exe.
After that i start P3d and pollypott software. It detect the PMDG B737-800 and its going in this mode.
The EFIS is working correct.
The MCP doesn`t work. No switches and no LED`s are working.
What can i do to fix the problem?
Do you need further information?
