Xplane 11.5b4 Rotate MD 88 file in progress
Hi.
i played around a bit and combined the MCP PRO with the rotate MD88. If everything works fine, I'll do some more tests and then if there is interest, I'll upload it.
Cheers
  • Hello
    the following allocations have been made:
    Rotary knob SPD= IAS selection
    Rotary knob SPD pressed= IAS Mach change
    Rotary knob HDG= HDG selection
    knob HDG pressed & rotated= maximum bank selection
    Rotary knob ALT= ALT selection 1000ft range
    Turn knob ALT pressed & rotated= ALT selection 100ft range
    Turn knob ALT pressed= ALT ARM
    CRS knob right= VS selection
    Display CRS Left= current IAS
    Display IAS= IAS AP selection
    Display HDG= HDG AP selection
    Display ALT= ALT AP selection
    Display VS= VS AP selection
    Display CRS Right= current GS
    Button N1= EPR Lim
    Button SPD INV= FMS Override
    HDG SEL button pressed briefly= HDG SEL
    Button HDG SEL long pressed= HDG HOLD
    CMD A= AP ON
    DISENGAGE= AP OFF
    All other buttons can be used normally as described. Send it to the developer today.
  • Did you ever upload the file? I just purchased teh Rotate MD-80 Pro, and would love to use your file to make my MCP-Pro work with it.
  • PM send
    Merry Christmas
  • Thanks,
    I replied to your PM.
