Xplane 11.5b4 Rotate MD 88 file in progress
Hi.
i played around a bit and combined the MCP PRO with the rotate MD88. If everything works fine, I'll do some more tests and then if there is interest, I'll upload it.
Cheers
Cheers
the following allocations have been made:
Rotary knob SPD= IAS selection
Rotary knob SPD pressed= IAS Mach change
Rotary knob HDG= HDG selection
knob HDG pressed & rotated= maximum bank selection
Rotary knob ALT= ALT selection 1000ft range
Turn knob ALT pressed & rotated= ALT selection 100ft range
Turn knob ALT pressed= ALT ARM
CRS knob right= VS selection
Display CRS Left= current IAS
Display IAS= IAS AP selection
Display HDG= HDG AP selection
Display ALT= ALT AP selection
Display VS= VS AP selection
Display CRS Right= current GS
Button N1= EPR Lim
Button SPD INV= FMS Override
HDG SEL button pressed briefly= HDG SEL
Button HDG SEL long pressed= HDG HOLD
CMD A= AP ON
DISENGAGE= AP OFF
All other buttons can be used normally as described. Send it to the developer today.
Merry Christmas
I replied to your PM.
