GF166A & GF45 Panels - No Displays Xplane 11
I have recently purchased two GoFlight panels. One is a GF166A and the other is a GF45. I use the Zibo 737-800 in X-Plane 11. I have the GF plug-in loaded in the core t folder and also have the X-Plane Go Flight Interface Tool. I have download the profiles from the Pollypot Software site that do load these into X-Plane. My issue is that the displays do not come on but when I plug them into the USB port the display their GF166 and GF45 displays them go blank. What is also weird is that the GF166 is working as I can tune to radios in the Zibo, I know because I turn the knobs and the radios change frequency fine.
Tried everything I know
Any help or suggestions would be appreciated.
To also advise, I have a GF EFIS and a GF MCPPRO and they both work fine. Power management unchecked on the USB ports.
Thanks for reading
Thanks for reading
The only thing I would check is the device brightness is set to 15.
Not quite sure what you mean about the "GF plug-in loaded in the core folder". I only have the GIT plugin-in for x-plane and a standard GoFlight software install for Windows 10.
Have known about the power management issue for a long time. I do it manually through device manager. I also did the Windows8Fixer today but it did not have any impact.
Thanks for messaging me though, appreciated.
Honestly, am usually quite good at working out what is wrong but I am totally stumped. Probably will sell my GF166 and GF45.
Weirdly my GF MCPPRO and GF EFIS work perfectly.
All the best
Rich
