USB or software probelm
Gentleman,
My goflight pro module has nothing on it, no numbers no dashes.
Could this be USB problem or software ?
Below is my Goflight Interface tool log
21:12:51 GoFlight Connection Starting.....
21:12:51 SimConnect Connection Starting.....
21:12:52 SimConnect Message Processing Started
21:12:52 GoFlight Connection Started
21:12:52 SimConnect Connection Started
21:12:52 Aircraft Connection Starting.....
21:12:52 PMDG SDK option is OK in Prepar3D v4
21:12:52 SimConnect: Event Received: Aircraft Type Changed
21:12:52 SimConnect: Event Received: SIM, 1
21:12:52 SimConnect: Event Received: PAUSE, 0
21:12:52 SimConnect Message Processing Finished
21:12:52 GoFlight Connection Starting.....
21:12:53 SimConnect Connection Starting.....
21:12:53 Creating Bespoke Vars
21:12:53 Bespoke Vars Created
21:12:53 Importing Bespoke Variables
21:12:53 Bespoke Vars Assigned, Importing Bespoke Events
21:12:53 Bespoke Events Temp Imported
21:12:53 Bespoke Events Imported
21:12:54 GoFlight Connection Started
21:12:54 SimConnect Message Processing Started
21:12:54 SimConnect Connection Started
21:12:54 Aircraft Connection Starting.....
21:12:54 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
21:12:54 SimConnect: Event Received: SIM, 1
21:12:54 SimConnect: Event Received: PAUSE, 0
21:12:56 WinSock: Connected To localhost On Port 27015!
21:12:56 LUA Processor: Started!
21:12:57 Aircraft Connection Started
21:12:57 Simconnect Version: 4.0.0.0
21:12:57 Aircraft FullName: PMDG 737-800NGX WL
21:12:57 Synchronising Switches & Selectors .....
21:13:01 Synchronising Switches & Selectors Complete
Thanks is advace
Nunesjoca
Thanks is advace
Nunesjoca
See the FAQ entry called "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/41-faq/70-faq.html
Carenado B350i King Air.
I have 2 green lights and yellow for the middle light and cannot select the MCP tab (its grey color) to set to zero and ENABLE.
Did an exetensive serach and read https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/41-faq/70-faq.html but with no sucess.
Below is my Log
16:03:41 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:03:41 SimConnect: Event Received: SIM, 0
16:03:41 SimConnect: Event Received: PAUSE, 1
16:03:42 SimConnect: Exception Received: OUT_OF_BOUNDS
16:03:45 WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
16:03:45 LUA Processor: Connect Exception - Unable To Connect!
16:03:49 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
16:03:49 Aircraft Connection Started
16:03:49 Simconnect Version: 4.3.0.0
16:03:49 Aircraft FullName: Carenado B350i_King_Air
16:04:12 SimConnect: Event Received: SIMSTART, 0
16:04:12 SimConnect: Event Received: SIM, 1
16:04:13 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:14 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:15 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:16 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:17 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:18 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:19 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:20 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:21 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:22 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:23 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:24 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:25 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:26 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:27 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:28 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:29 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:30 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:31 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:32 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:33 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:34 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:35 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:36 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:37 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:38 SimConnect: Exception Received: OUT_OF_BOUNDS
16:04:41 Synchronising Switches & Selectors Complete
Thank you for your assistance
It's either because the Goflight Interface Module.dll is not loaded (check your dll.xml for its presence) or a firewall is blocking TCP/IP comms between GIT and the dll.
I inserted the entry and now I get 3 green lights.
I select MCP then Device 0 and ENABLE but nothing happens even after re-starting both the application and my computer.
Did this now several times but my MCP is still showing all zeros.
I followed the steps- My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)
What am I missing? (again with my MCP PRO and PMDG everything works perfectly )
Thanks again Steve
