MSFS Aerosoft CRJ 550/700
Is there anybody who could make a MCP-Pro setup for the new Aerosoft CRJ?
Would be great.
Thanks in advance,
Martin
  • Yes me .....
    I'm working on it. Altitude change is not working currently. Maybe Aerosoft issue. I have to ask them on the official forum.
    Try this attached and let me know.
    Francesco
  • I’m curious how you’re building that profile? I built one for the P3D version but the detective tools etc don’t seem to be working in the MSFS version so I couldn’t start digging into the MSFS version.
    I’ve found that using a default profile some things work but as you’ve noted altitude select firmly does not work.
  • Hi Francesco,
    thank you for your effort. heading works (without the displays), but altitude doesn't work. Which MCP-Pro buttons/rotaries should work?
    Martin
  • Hi Martin,
    not sure it can work. That's something I nned to investigate. CRJ has not AP with clear display values, if not in the MFD, so don't know really if it possible. (I mean like in the 737 MCP)
    Coming to the Altitude, I have undestood during these days that this depernds on how Aerosoft has build the code. There is no value matching the origin code value (it is using LVAR values and not default values) .... So im not a programmer and im stuck here, This is very annoying, using the mouse to rotate Alt with head tracking is tricky.
    Theoretically all the buttons ans rotaries should work with CRJ and Polly. As you can see already Speed, HDG, CRS Left, VS rotaries are working and all the buttons, ALT, HDG, LNAV, VOR/LOC, SPEED, V/S, and so on... I'm introducing new settings currently when pushing rotaries (they have also a button not only rotary functionalities). I'll post new XLM when ready here.
    But, I would need help for ALT.... I'm looking around on forums to undestrand better the matter.
    FRancesco
  • edited March 2021
    dr1980,
    I used Polly's internal funtions to map rotary and buttons. AFAIK there is not Detective function for MSFS.
    Yes this is the challenge, ALT is using LVAR varialbles. All LVARs are listed in the Aerosoft official forum but I have not idea how to match those with polly or with FSUIPC.
    Are you skilled on that ?
    Francesco
