CaptainSim 767_II v 1.0 MCPPRO
https://www.dropbox.com/s/rquf5l5o8vtkyn8/CS_B767-300ER_II_PW4060.7z?dl=0
My first attempt at an aircraft profile for the MCPPRO.
Heading pushbutton is assigned as Heading Select and HDG button assigned as Heading Hold as per the aircraft
Minor problem...IAS displays 0 when in VNAV. If I use display blank etc then IAS displays speed with two decimal points i.e. 250.00 when out of VNAV.
Attempted VS but not had chance to correct it yet......any suggestions tips will be most welcome.
Norm
Norm
