programming the MESM-module for the ZiBO mod.
Hello Captains,
I need some help with programming the MESM-module for the ZiBO mod. If programming is possible?
In the MESM menu you have 7 positions to work with. I am able to manually move an selector knob from OFF to GRD and then back to OFF and further on to CONT en FLT and the ZiBO mod selector is responding. So far so good...
But at this point = position 5 has to be programmed I get stuck and don't know how to get back from FLT to CONT and then to OFF.
For all the above actions I made bespoke events (f.e. ENG2 OFF to GRD ) using the "67922 laminar/B738/knob/eng2_start_right" and "67923 laminar/B738/knob/eng2_start_left" commands.
Expecting to use 67923 laminar/B738/knob/eng2_start_left at position 5 doesn't work...
Strangely: testing the bespoke events I made in Detective, I am able to let the selector move from FLT via CONT to OFF using the laminar/B738/knob/eng2_start_left" command.
Any ideas what I am doing wrong?
Kind regards,
Jan.
  • Can you provide the details of your bespoke events for positions 5 and 4.
