MSFS2020 - GIT Stopped Loading FBW A32NX for MCPPro
I have been running the GIT using the FlyByWire A320 successfully in the MCPPro and EFIS for many months now with no issues.
However, after recently starting GIT, no aircraft information is seen in the Aircraft section of the status page, where is typically shows FBW A320 loaded. It just says None, and while the green light below is blinking, no tabs or buttons work in the GIT.
I recently updated FSUIPC7 to 7.2.8, and have not been able to power up the MCPPro with any lights or knob functionality.
Attached is a snapshot of the GIT, and a copy of my log file. It appears the log file stops at the same point each time.
Any assistance or guidance is greatly appreciated.
Steve G.
  • UPDATE: I was able to get "Flybywire_A320_NEO" to appear in the Aircraft section on the status page of GIT. The green light below it is blinking. The devices MCPPro and EFIT display a "1" indicating it knows what I have configured. However only the Log and the Status tabs in GIT function, cannot click any other tabs or buttons. And still no lights on the MCPPro.
    I have:
    1. Removed and reinstalled GIT from my account
    2. Removed and re-added the WASM module to the Community folder
    3. Tried moving the MCPPro USB to another port location, although it had been running without any issues in the original location.
    Not understanding why the log shows the load stops at specific LVAR's each time.
    Steve, any thoughts or suggestions would be greatly appreciated.
  • UPDATE: I tried testing the MCPro and the EFIS using the default C172, and lo and behold, the MCPPro lit up and functioned using the heading knob and EFIS using the baro. So I know both MCPPro and EFIS are communicating with my PC and MSFS.
    The FBW A320 development version will not operate, however, and still appears to halt during the load of LVARS in the same exact line every time. And like before, the buttons and tabs in the GIT interface will not operate.
  • Is there a limit to the amount of aircraft data (LVARS, etc.) that can be loaded into GIT? The log ends at Line 3900 every time when starting GIT on the latest version of FBW A320NX.
  • Yes, the limit is 10240. Is there an entry for this aircraft in KnownLvars.xml file in Documents\GoFlight Interface Tool?
    Can you post the Log.
    Yes, the log is attached above in my first post. The initialization appears to stop at the same LVAR/line every time.
    What's odd is that I see LVARs in the log for other aircraft as well as the A32NX, such as the Aerosoft CRJ, DA62, 747-8, etc.
    My KnownLvars is VERY long, over 14000 lines.
    Much appreciation for your help.
    Steve G.
  • I did test GIT using the default C172, and GIT initialized completely and perfectly. The log was short, and there were some other aircraft LVARs loaded but nowhere near the number when loading the A320NX.
    I've been using GIT with the A320NX for months and its been solid, no issues.
  • OK, this looks like a possible bug in GIT because the last Late Lvar in the Log is the last one listed for this aircraft and then GIT should start up. I will look into it.
    It would be interesting to see what happens if you remove all the late lvars for this aircraft in KnownLvars. Start GIT with this aircraft in VC mode, wait a minute, quit GIT so that KnownLvars is updated and then start GIT again and see if the problem remains.
    OK, thanks.
    But get this: after update to MSFS 2020 and installing World Update IV, the GIT and MCPro appear to be working. I am baffled by this, but happy nonetheless...!
    Attached is the log file AFTER the update. Look toward the bottom where it loaded all LVARs and then created the Bespoke Vars. It continued passed that last LVAR and completed initialization.
    11:47:57 Late Lvar Detected: XMLVAR_Cabin_Heat_2_Position
    11:47:57 Creating Bespoke Vars
    Bizarre...
    I'm going to keep testing to ensure this occurs every time GIT is loaded.
    Steve G.
  • I did some testing by loading the simulator a number of times and configuring the FBW A320NX, then starting GIT. The results were sporadic, sometimes GIT would initialize and other times it would stop at the exact same line in the log.
    Following Steve's advice, I began to remove LVARs associated with the A30NX in the KnowLvars XML file. I soon realized its an impossible task since (1) it is 14000 lines long, and (2) there are LVARs that are difficult to tell whether they are associated with the A320NX. So I stopped and went to the extreme, deleting the KnownLvar.xml file and let it rebuild itself by loading up the A320NX in the sim. It seems to have reset itself and now I'm able to get GIT to initialize complete each time. I will continue to test this evening and advise on my results.
    Thanks for all assistance....
    Steve G.
  • I'm getting a fix out today.
  • New version is available.
  • Thanks Steve! I will download and test this evening.
    Much appreciation for your help and support....
    Steve G.
  • Steve,
    Just letting you know that all is working well after the most recent update to GIT and the WASM module. I have tested with a few flights using the FBW A32NX, on the EFIS and MCPPro. I will continue to test with other aircraft as well and advise of any issues.
    Thanks again for your wonderful support....
    Steve G.
