MSFS MCP-Pro Altitude Lights with Working Title Garmin 1000 NXI
With the last update of the Working Title G1000 NXI the altitude light doesn't work and show a value of "99000". In the documentation I found the following "for your Autopilot Panel, make sure that the Display value for Selected Altitude is using ‘AUTOPILOT_ALTITUDE_LOCK_VAR__1’ instead of ‘AUTOPILOT_ALTITUDE_LOCK_VAR’". https://www.workingtitle.aero/packages/nxi/issues
In GIT I found the value ‘AUTOPILOT_ALTITUDE_LOCK_VAR’ but don't found ‘AUTOPILOT_ALTITUDE_LOCK_VAR__1’. Is there a way I can add it or must I wait on a new version of GIT?
Martin
Martin
Best wishes,
Martin
I will test if that's the case tomorrow and if so, get a new version out tomorrow.
Best regards,
Martin
Best wishes,
Martin
