Go-Flight MCP Pro stuck on 99000 ft
Go-Flight MCP Pro stuck on 99000 ft on certain aircraft since the new update 6 in MSFS, those planes are
DA62.
Cirrus SR22
Textron Aviation Beechcraft Baron G58
" " " Bonanza
" " Cessna 208B Grand Caravan
" " Cessna 172 Skyhawks (all of the variations)
Cub Crafter X cub
Anyone else using Go Flight MCP suffering this problem?
DA62.
Cirrus SR22
" " " Bonanza
Cub Crafter X cub
It also be worth checking your MCP is broken. I have a copy of GoFlights test program here: https://1drv.ms/u/s!AvmOqBMETlayh9ZQKy3urkyHuWeNEw?e=aLKfs1
To be clear, I'm using the latest version of MSFS with the latest GIT and GIT WASM module.
I wonder if the MSFS update didn't install properly for you and messed things up.
I also tested the DA62 with my forthcoming new software and it all worked OK as well.
It has to be something gone wrong on your PC, or your MCP is playing up.
See the high-lighted fields in the attached image. Select Device 0, then an Input of DISPLAY ALTITUDE and then change the Light/Disp Data to the required variable AUTOPILOT_ALTITUDE_LOCK_VAR1
I may have missed it, but what plane are you configuring in the GIT screenshots?
Steve G.
MPC although lit up and displaying 0 on each screen, but none of the knobs will operate anything like Heading, Altitude or Course etc etc. All stay on 0. But if I go into the cockpit and change anything like set altitude or Heading the display on the MCP does change accordingly, The MCP is simply not working using it's own knobs.
Does turning the knobs change the setting values in the simulator, such as the heading, altitude or airspeed, even though the MCP displays stay at zero?
Do you have any bespoke events programmed in Detective to change the settings, incrementing or decrementing?
Dave
