PMDG interface tool and the new NGX poisedon doesn't work for FSX
Hello everyone,
just wanted to see if anyone is having issues with the new updated PMDG NGX poisedon for FSX???
Mine dosen't seem to work at all
Dwayne
Hi Dwayne,
A repaint won't break the interface. Are you laoding the NGX twice and triggering the PMDG SDK bug?
Hi Dwayne,
Can you give me the exact repaint version/details you are using and I'll try it on my PC.
Hi Dwayne,
I have just downloaded and tried the US Navy P-8A "Poseidon" of VP-30 "Pro's Nest" at NAS Jacksonville, FL from Avsim and it works fine. Are you using an older repaint perhaps?
PS, what do you mean by "the new updated NGX?" Are you referring to SP1d as I don't have it yet!
Ok, it must be that the aircraft name has changed. GIT looks for "PMDG 737" in the aircraft name to determine the NGX has loaded.
A temp workaround would be to change the liveries "title" in aircraft.cfg so the string above can be found.
Great. I'll add some PMDG Poseidon detection code in the next release.
