GIT FS2020 - Strange issue after new update.....
I read something similar in some previous post here but I want to call your attention to this issue...
After MSFS last update I was able no more to start the engine cycle of my plane ( I use TBM 900) as I was having always a MSFS Ctd.
I tested everything and I was surprised to discover the problem in GIT module inside the community folder.
Without the module everything runs well again.
Now i found a solution...I'm starting no more the Git program after the plane is loaded into the simulator, as I was used to do, but when the world map is open, in any case before the flightplan is loaded into the simulator.
It seems to play correctly in this way.
Anyway I want to put this issue to the attention of Steve as I suppose it is not normal so to find a possible solution for future update.
Just to know I use the last Git and module updated on your site.
Maurizio
p.s. sorry for my english!
  • I'll look into it.
  • Steve,
    unfortunately the previous solution was not good.
    At the moment no possibility to start the plane without a MSFS ctd with the GIT module inside the community folder.
    I spent a lot of hours to find a solution but no idea.
    The problem occours also if I try to start the plane without launching the GIT program before.
    May you help me?
    Just a question...I have installed Git store version but I Have FS2020 boxed. Should I use your box version? what is the difference?
  • I have just tried to re-create the issue without success. The TBM 930 starts up with no crashing, so something must be wrong with your setup.
    I would delete all installations of the GIT WASM module, download the module from your account and install into your community folder. FS2020 will recompile the module, so it may take a while to start up.
    The different versions just install the WASM module to the correct Community folder as each version of FS2020 has a different location for it.
    I must apologize with you as I spent a lot of hours on the Git module but I have just discovered that the issue I described you is related to "working title g 3000" mod.
    As far as the Git module is concerned everything is ok.
    Thanks anyway for your kind cooperation.
