Devices remain inactive
Since I had to reinstall GIT for the FS2020 store version, all devices remain dark. No matter how I try to configure. The USB connections are OK. They are recognized in devices and printers and also light up when the PC is started.
thanks for your help
Peter
Peter
Can you post your GIT log.
where can I find the log file?
Can you also confirm if the rotaries, buttons and switches work?
The GF-LGT works. The controllers do not work on the GF-MPC. Nothing works in the GF-166 either. GF-T8 is inactive. The LEDs are off on all 3 displays.
Thank you for your efforts
Peter
In the attachment I will send you the settings.
Also, does this problem impact all aircraft or just the one in the log?
I am desperate. I deleted all entries that had to do with GoFlight and Pollypot, restarted the system. Software installed. Now I get a field message when installing. Although I turned off the translation.
frustrated greetings
Peter
Again, does this problem impact all aircraft or just the one in the log?
It seems to affect all aircraft. I also tested the Cessna C152, Pilatus Porter and JU52. All displays remain dark.
Greetings Peter
Try running Windows8Fixer from the Goflight drivers. How to use it is detailed in the Goflight readme file.
The Windows8fixer tool is no longer available for Win10. What should I do. Can you recommend an equivalent tool to me?
Greetings Peter
Could it be that the latest Win10 update, see attachment, is to blame for my big problems?
With kind regards
Peter
Now it worked. Everything OK.
Thank you again very much for your great support.
many greetings Peter
